Mk2 votex roof bars
sciroccosi
Mk2 votex roof bars
Hi chaps has anyone got votex roof bars as I have some but I think there is a bracket missing where it bolts under the tailgate strut and I'd like to see a photo if anyone can help, I've had them years and I'm just thinking about putting them on thanks in advance Si
Re: Mk2 votex roof bars
Will get them out tomorrow afternoon (I need to take a pic for my advert anyway)
sciroccosi
Great stuff thanks, I'm hoping that it's will be easy to fabricate, I think it bolts to the bars then goes under the strut
sciroccosi
- RossWP
How do they attach at the door end? I've just acquired a set and cant work out if I'm missing a piece or something.
Scirocco Register Member Number 1297
1986 GTS Auto
1986 GTS Auto
DannyH
It's common for the connectors that screw in under the gas struts to be missing.
i'll try and find some photos for you.
i believe it's possible to have them made up.
you can use them without but not recommended.
Danny
- RossWP
Sorry, I meant the front end. I've got the bits at the back.
At the front there are allen bolts but I can't see how they tighten on to anything?
1986 GTS Auto
1986 GTS Auto
- Blueshark
There should be a strip of metal over the roof from left to right which go under the bars and is tightend by the allen bolts.
- Blueshark
https://www.google.nl/search?q=roofbars ... nc2iEZM%3A
Black strip just behind the front window seal
- RossWP
Thanks Joost, don't suppose anyone has one that could measure dimensions? I'm definitely missing that part
1986 GTS Auto
1986 GTS Auto
DannyH
if you're not in a hurry i've got one but i'll be away for a fortnight.
hopefully someone else can get it to you quicker
Danny
- RossWP
No rush, any help would be much appreciated
1986 GTS Auto
1986 GTS Auto
