Mk2 votex roof bars
sciroccosi
Mk2 votex roof bars
Post by sciroccosi »
Hi chaps has anyone got votex roof bars as I have some but I think there is a bracket missing where it bolts under the tailgate strut and I'd like to see a photo if anyone can help, I've had them years and I'm just thinking about putting them on thanks in advance Si :-D
mr.brown
Re: Mk2 votex roof bars
Post by mr.brown »
Will get them out tomorrow afternoon (I need to take a pic for my advert anyway)
sciroccosi
Great stuff thanks, I'm hoping that it's will be easy to fabricate, I think it bolts to the bars then goes under the strut
mr.brown
Post by mr.brown »
Just realised a ruler would have been a good idea
sciroccosi
That would be great but the photos should be OK now I have the shape cheers
RossWP
Post by RossWP »
How do they attach at the door end? I've just acquired a set and cant work out if I'm missing a piece or something.
Scirocco Register Member Number 1297
1986 GTS Auto
DannyH
Post by DannyH »
It's common for the connectors that screw in under the gas struts to be missing.
i'll try and find some photos for you.
i believe it's possible to have them made up.
you can use them without but not recommended.
Danny
RossWP
Post by RossWP »
Sorry, I meant the front end. I've got the bits at the back.
At the front there are allen bolts but I can't see how they tighten on to anything?
1986 GTS Auto
Blueshark
Post by Blueshark »
There should be a strip of metal over the roof from left to right which go under the bars and is tightend by the allen bolts.
Blueshark
Post by Blueshark »
https://www.google.nl/search?q=roofbars ... nc2iEZM%3A
Black strip just behind the front window seal
RossWP
Post by RossWP »
Thanks Joost, don't suppose anyone has one that could measure dimensions? I'm definitely missing that part :-(
1986 GTS Auto
DannyH
Post by DannyH »
if you're not in a hurry i've got one but i'll be away for a fortnight.
hopefully someone else can get it to you quicker
Danny
RossWP
Post by RossWP »
No rush, any help would be much appreciated :-D
1986 GTS Auto
