After 7 Years, A Solution
Risocco
Post by Risocco »
Chuffed
marcus
Re: After 7 Years, A Solution
Post by marcus »
That's it?! You're not going to tell us what it is and how you did it?!
1985 GTL 1.8
Old Mac Rocco
Post by Old Mac Rocco »
Or a slightly modified Tool clip ???????
From this ..........
To this ............
Risocco
Post by Risocco »
marcus wrote:That's it?! You're not going to tell us what it is and how you did it?!
Woah, completely forgot about this thread.
http://www.ebay.co.uk/itm/311416732212? ... EBIDX%3AIT
All you will ever need, just introduce old hole to a 10mm drill bit.
Roccogtx332
Post by Roccogtx332 »
Brilliant idea, nice one
Rocco '86 GTX all original driving project
What were they? Listing got removed :(
p in phcas
Post by p in phcas »
I used a 10mm central heating pipe clip from B+Q. Maybe should have mentioned earlier?
unknownmale
Post by unknownmale »
unknownmale
The pole on the parcel shelf is 8.5mm incase anyone was desperate to know. So 10mm is just the right size
Thanks dude, just ordered them. Appears to be a pack of 10? So if anyone wants to buy the left overs, just shout!
rosie
Post by rosie »
Did they work Nate? Did you need to increase the size of the hole?
1992 GTII 1.8 black
Brighton
Running it into the ground
rosie wrote:Did they work Nate? Did you need to increase the size of the hole?
if you look at my link you can order a clip in various different sizes and they do one that is 9mm and presses into a 6mm hole so will most likely fit straight into the existing hole without the need to drill the existing hole out.
