After 7 Years, A Solution
Re: After 7 Years, A Solution
That's it?! You're not going to tell us what it is and how you did it?!
1985 GTL 1.8
- Risocco
Woah, completely forgot about this thread.marcus wrote:That's it?! You're not going to tell us what it is and how you did it?!
http://www.ebay.co.uk/itm/311416732212? ... EBIDX%3AIT
All you will ever need, just introduce old hole to a 10mm drill bit.
What were they? Listing got removed :(Risocco wrote:Woah, completely forgot about this thread.marcus wrote:That's it?! You're not going to tell us what it is and how you did it?!
- p in phcas
I used a 10mm central heating pipe clip from B+Q. Maybe should have mentioned earlier?
- unknownmale
- unknownmale
The pole on the parcel shelf is 8.5mm incase anyone was desperate to know. So 10mm is just the right size
- David
Thanks dude, just ordered them. Appears to be a pack of 10? So if anyone wants to buy the left overs, just shout!the edmundator wrote:http://www.ebay.co.uk/itm/171777978981
Did they work Nate? Did you need to increase the size of the hole?
1992 GTII 1.8 black
Brighton
Running it into the ground
Brighton
if you look at my link you can order a clip in various different sizes and they do one that is 9mm and presses into a 6mm hole so will most likely fit straight into the existing hole without the need to drill the existing hole out.rosie wrote:Did they work Nate? Did you need to increase the size of the hole?
