well not done much over winter apart from getting the tracking and cambers sorted a few months ago, i actually have some weight in my steering now!!!!
still havent sorted out firring the brake crap guards, although i;ve just got some elongated sockets which fingers crossed will fit through the wheel bolt holes as they line up with the crap guard ones, I'll keep you all informed on progress!!!!
the only real big thing I;ve done is put back on my Ronal 5 spokes, i wanted to test to see if they were still running following the change in suspension to coilies and a propercamber set up. As you may know i have different profile tyre fitted, lower ones on the fron originally (with the added issue of my speedo being wrong!!!). So i started out by fitting the original rear ones to the front and taking it out for a proper test, including some uneven roads (lots near me) and a few roundabouts to get the car turning and leaning. Well not good, straight out and the running sound from a dip, but after that all seen good until the final 360 roundabout run and yes some rubbing, not a lot but enough.
so it was back home and a change to the lower profile one (approx 10mm more clearance) went out and nothing yeah. So the plan is not to do a DIY refurb on these and replace all the rubber. As it turns out a set of 4 of the lower profiles ones is only £151 delivered compared to just over £200 for th others so another bonus. At this rate i should have them re-shod and refurbed for about £200 :)
any how, after another 18months in the garden you can see they'll need some work-
but with an offsett of 25, they fill the arched so much better ;)
so over the next month or so I;ll be getting these sorted, all i know is they'll be a very light silver, still not sure about doing the recesses in satin black though hmmmm
