How I got it,
Jobs done over my ownership-
Suspension replaced 40mm lowered (done by a mate)-
Rear seatbelts replaced with inertia ones so my littles ones car seat could go in the back-
Replacement fuel tank with a refurb (put back in by mate with a car lift)-
Long grill made and fitted-
Tinted rear lights-
Refurbed fuel filler neck-
Towing hooks painted-
Side vinyl removed-
Fog lights changed and clear indicators-
Splitter custom made (by a mate)-
Unfortunately someone decided they liked it more than me and removed it from the car one night!!!
Front and rear brakes replaced and refurbed-
Along with all the above the cars been regularly serviced and had a few bits like an alternator, suspension top mount, a wheel bearing, cam belt, changed Cam Seals (done by mate), Rear Bumper replaced, speaker upgraded etc
How it looks now-
 With old P slots, long story but ended up with thin rubber on the front and the 5 spokes fitted
All the above is detailed with more pics over on SciroccoUK, in the project area, White Scala
However due to the last few hard winters a job list has started coming together for essential works this year (before the national meet)-
- Few rust spots around the rear lights/number plate need sorting and painting
- 2 bad rust spots in the boot on arch to the back of the welds for the fuel filler neck brackets
- Refurb rear ARB, one of the clamps has rusted through so will remove, replace bushes, clean, paint etc
- Service with K&N air filter
- Handbrake cable (the adjuster thread is screwed and with changing the drums won’t go tight enough to hold on handbrake lever, cable ties currently helping out)
- Rust to rear of bonnet (preventative the bonnet will need to be replaced at some point)
- Swap passenger door, rusted through in middle and along quarter window, I have a replacement but struggling to get the counter sunk screws out of the latch, they rounded!!!!
- Swap quarter window in drivers side (current one isn’t tinted)
- Full detail and clean
- Get and fit auxiliary gauges
- Carport to protect car this winter
I have no doubt this list will increase as the year passes!!!!!!
Okay time to get started lol
