Next job on the list was to remove the rear anti-roll bar due to one of the clamp straps rusting through so was going to refurb it etc. Unfortunatly I rounded one of the bolt heads :( I was going to struggle to get the other one loose anyway as the fuel tank was in the way (had the car on ramps so I was going to jack am i right in thinking that the beam would have rotated to allow access???) ended up just fitting the replacement strap, checked over the rubber bushes and althougn they were slightly perished there was no play around the bar :)
broken strap-
nearly there-
And done-
Since i had some time decided to look at the front steering its had a slight bit of play in it and the steering wheel isnt straignt, so had a look at the track rod ends, and all good but did notice that the wheel bearing noise as i though wa actually the wheel rubbing on the arch!!! so took it to the local Smiley garage to get the tracking done. Was shocked when he said the tracking wouldnt sort out the camber as they dont look at that!!!!!! he said it needed to go over to over to a specialist performance garage. So will be popping over to Awesome near me next weekend :)
Concerning the anti-roll bar looks like I'll be removing the rear beam next spring and doing a full refurb in it :)
