mk2 filler neck
mk2 filler neck
Hey, ive got a project going on at the min and as usual the fuel filler neck is rotten. Where do people get there fuel necks from as ive been searching for the past few weeks with now avail.
Cheers,
Liam
Cheers,
Liam
Re: some help
i think ive herd gsf or ecp do them, also herd that you can use a mk1 golf one with a bit of trimming?
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
Re: some help
Yes, you can cut a mk1 Golf filler neck down do size and make it fit ok.
Re: some help
If you are struggling to find one let me know as I have a Golf one (brand new) that I was storing just in case!
Village Idiots
Re: some help
I recently fitted a new neck to my Scala. GSF had the parts: Mk1 Golf neck and rubber pipe to connect to tank.
I did a detailed post of how to fit in the fueling section.
Re: some help
Also e36 BMW 3 series ones can be made to fit with a bit of heating up, mark h did this on one of his project cars - advantage = they're plastic if you cant track down a new one or a stainless steel one.
mazellann
Re: mk2 filler neck
Are there different types of mk1 golf filler neck, the one i bought couldn't be made to fit, the top part of it was totally different to a scirocco one?
Re: mk2 filler neck
I think the cabriolet has a different filler neck to the hatch. But either way, the cap end is still different and you can't re-use your original cap.
Village Idiots
Re: mk2 filler neck
Check my post in fueling section. You can re-use your filler cap by a bit of careful cutting and welding.
- steve GT VW
Re: mk2 filler neck
hi all
I have this issue too although its not so urgent as I have LPG, was wondering if anyone had tried to fit and internal rubber or plastic sleeve to the neck instead of have all the issues with replacing the neck its self?
I dont need to use very often and only put 1 gallon in a year, so do you think it would be possible???
let me know your thoughts
Steve
Steve
Re: mk2 filler neck
if it's just pin-holed, trat it with POR15 tank sealer. should do the trick nicely
- steve GT VW
Re: mk2 filler neck
just put the car back together, Tank sealer did the trick, took 4 days to dry, but was fairly quick to do
Steve
Steve
