spring caps
spring caps
what do you think the chances are that these are the same part??
https://www.vwheritage.com/shop/scirocc ... StartRow=1
https://www.vwheritage.com/shop/mk3-gol ... StartRow=1
all except the PRICE!!
Re: spring caps
They do look the same in the pictures but without seeing them in the flesh and comparing size it's hard to tell.
They don't seem to but any sizes on the website.
Re: spring caps
i will give them a call tomorrow and find out as i have spare caps to hand i can measure and see if theyre the same. for that price its worth looking into!
steve bain
DT1
Re: spring caps
The picture is deceiving, the Mk3 cap has an indent to locate the end of the spring, bit like the bit on the strut...the Scirocco one doesn't. Of itself that shouldn't necessarily cause a problem if the other specs are the same.
Re: spring caps
http://www.mig-welding.co.uk/forum/data ... 83d85a.jpg
http://www.mig-welding.co.uk/forum/data ... 5ca2df.jpg
heres a piccy of them in progress
Re: spring caps
Why are you extending them?
I can't work out what you are hoping to achieve?
Re: spring caps
standard springs are too high
lowering springs start at 40mm and are too low.
eibach springs with 20mm added to the spring cups gives me 20mm lowering which should be about right and gives 20mm more shock absorber travel before botteming out which eibachs have a habit of doing to shocks
mr alpine92
Re: spring caps
nice james let us no how it work out with yours,i get them picturs for you this week,james butler wrote:standard springs are too high
steve bain
Re: spring caps
I vaguely remember from yonks ago before I got coilovers that boge shocks from gag were gas and had a bit more travel than most. They were pretty fairly priced too.
Re: spring caps
trouble is the springs set the ride height so it will still give the same issue by sitting too low on the suspension.steve bain wrote:I vaguely remember from yonks ago before I got coilovers that boge shocks from gag were gas and had a bit more travel than most. They were pretty fairly priced too.
duggers
Re: spring caps
Just before I sold my 16v rocco the standard springs needed replacing (one broken on the front-bugger!) and I found some 25mm lowering springs which worked well with standard springs just trimmed the bump stops to suit.
Membership # 432
Membership # 432
Re: spring caps
i did cut the bump stops but it just proves that the ride is too low for the current dampers and will inevitably lead to damage hence why i made these.duggers wrote:Just before I sold my 16v rocco the standard springs needed replacing (one broken on the front-bugger!) and I found some 25mm lowering springs which worked well with standard springs just trimmed the bump stops to suit.
Re: spring caps
heres a few pics of the caps fresh back from the powder coaters.
[=http://s1382.photobucket.com/user/james ... k.jpg.html]
[/URL]
[=http://s1382.photobucket.com/user/james ... d.jpg.html]
[/URL]
[/URL][=http://s1382.photobucket.com/user/james ... d.jpg.html]
[/URL]I dont mind project cars but I HATE SANDING!!!
