help needed in yorkshire or not two far lol
hey up peeps,
i was just wondered if anyone would like to give me a hand i need to swap a 5th gear in my gearbox for a tall one and havent got a clue how to do it and swap my manifold over to a stainless one , i have a lovely warm garage and plently of tea lol feel free to let me know
regards
lee
regards
lee
SCIROCCO GT
Member 934
Member 934
Re: help needed in yorkshire or not two far lol
change the gearbox for a GTL 4 + E type one... it'll be a lot easier
Mike Simcox
'The Founder'
Mk1 Vr6 - MCA Sports - Renault Van...
'The Founder'
I have a gti box on and like the rev range with the gti cam I have just want low 5 gear for the motorway driving I do
SCIROCCO GT
Member 934
Member 934
deffo the 4 + e then... i seem to remember its near enuf the same ( but i am sure that an anorak on here will be able to tell you exactly) apart from the 5th ' economy gear. designed for exactly what you want. I am sure changing a cog in a box is gonna be a specialist job with specialist tools. And i betya somone on here has a 4 +e box laid around...
Mike Simcox
'The Founder'
'The Founder'
nobody wants to help me lol instead of the gear swap hoe easy is to swap the flanges over as i am running 100mm drive shafts and i have a 4+e box and there have 90mm ones
SCIROCCO GT
Member 934
Member 934
nobody want to help me lol, how easy is it to swap the gearbox flanges over from 90mm to 100mm as i am running new 100mm drive shafts i have a 4+e box
SCIROCCO GT
Member 934
Member 934
i can help you do the mainifold but i think i may be out of my depth with the gbox?
does it look easy to do?
swaping the flanges is easy really, done it a few times, even have my own "tool" that the hyanes goes on about, is just a 5mm thick steel bar with a long bolt through it
i should be off to get a new car on sat/sun from liverpool so could stop on the way back?
drop us a pm mate :)
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
beat me too it... drive flanges isnt too hard...
problem solved..
problem solved..
Mike Simcox
'The Founder'
'The Founder'
- fonzooorooo
It's a bit warm for my anorak, so faded black t-shirt will have to do...
Gear ratios - in the 4+e:
1st is the same as 1st in the 5 sp.
4th is the same as 5th in the 5sp
e is higher than 5th
2nd and 3rd are both different to fill the "gap" difference between 1st and 4th on the 2 boxes.
I always feel the rocco's crying out for a 6 sp. box - all the ratios of the 5 sp, + the e from the 4+e.
What I do:
- filmidget
On anything other than motorways I found using a 4+e mated to an 1800 (with hot-ish cam) less than ideal due to the significantly bigger gaps between gears.
Used to have to drop two gears to get in the power - never used 4th or 5th when 'pressing on' on A- or B-roads!
Wouldn't a gearbox from the Mk2 Golf 16v do the job?? Good gearing throughout the range for keeping it in the power, just that 5th is a bit longer for the extra top end. Its just an 020 jobby same as rocco basically. The 4+e will do your head in.
Also, if you need a hand, i may be able to help out over the next few weeks as i have annual leave. Not stripped a box, but hey......always willing to learn.
