Took the plunge today and decided to tackle the rotten wheel arches. Started with the drivers side, as i knew it was in better shape than the passenger side. What i found  under the body kit didnt really come as a surprise....
so out with the grinder, and off with all the rotten metal.
The donor arches were cut from ONX before it was scrapped, they needed a bit trimming to get a nice fit.
When i cut the arches from Onx, i cut well into the inner wheel well to get plenty of metal to work with. This means that the arches can be MIG welded in the wheel well and the outside of the arch to give it plenty of strength.
Once i was happy with the fit, i temporarily pop riveted the arch in place until im ready to MIG weld them. Very pleased with this one so far..
Then came the passenger side. Now i knew this would be bad, but it was worse than i expected....
The rot has also got to about a third of the way along the sill from the arch, and also on the back edge of the sill behind the beam mount.
  Now at this point i must admit i was wondering if i should carry on, but after a quick brew to get over the shock and weigh the job up, i got cracking again. I cut out all the rot, and then started to trim the new arch to fit...
Obviously theres no point in riveting the arch in place, as ive got to make plates to repair the sill, and the inner sill by the beam mounts. So i just got it fitted snugly and called it a day.
The remains of the arch...
Granted theres a lot of work to do, but im looking forward to getting to grips with it all. It just so happens that id recently got a set of urethane beam mounts off Ebay, so seeing as the beams coming out to do the welding, i'l fit the urethane mounts while its out, and change the rear brake hoses, so its all worked out nicely really.
Wont get anything else done until monday now as i'm off to Manchester for the weekend with Lynne and the kids, so before i stuck the car in the garage, i wire brushed the beam mounting bolts and soaked them in WD40 to hopefully make things easier on monday.
