Help!
batman
Help!
Post by batman »
As the sun is out I thought i'd get a few jobs done on the Scirocco today. I've just replaced the air filter with a nice new k&n one, but after replacing the air cleaner cover and re-fastening the clips, I dropped the mounting nut into the engine bay - doh! It looked like it went in behind the alternator and I can't find it - it definitely isn't on the driveway either! Now I can't find a suitable nut to take it's place. Firstly, can someone tell me where to get a replacement, and secondly, is it safe to use in the mean time? Thanks
Boumsong
Re: Help!
Post by Boumsong »
Got a jetwasher? If so, give the area where you think the nut has gone a little blast, should see it drop out to the floor then. Try and keep the water away from air intake and spark plugs etc etc though.
2k Painter and Powdercoater
wiredsubzero
Re: Help!
Post by wiredsubzero »
ive heard a good way is if you have a good hover get the hose and put a thin sock over the end and tie it on the extending pipe with a rubber band and hover around that area it should suck onto the sock .
i havent tryed this myself but ive been told its good
Re: Help!
this has happened to me so many times usually it gets tapped at a bit further down behind w/pump housing.use a magnetic pen an reach round the back of alternator n in the area. wouldnt like to say if it would be ok to run it wivout knowin where its gone.
