Turned her over yesterday and there was a slight noise, like something flew off upon starting, and the car will not idle happily at all. Have to pull the choke out a fair way to idle around 1800rpm. Won't idle at anything lower. Have not run the car up to temperature incase I cause further damage.
Opening the bonnet with the engine running there is a rather loud hissing noise, like pressurised air escaping. Either from the head or carb can't quite pin-point it.
No play in the carb gasket which was my original thought, any ideas chaps? Any help would be grand
Alex
