Upgrading brakes - G60 Calipers
ash-lough
Post by ash-lough »
Im looking at upgrading my front brakes to 256mm discs.
I have been offered some G60 calipers, carriers and hoses for a very reasonable price, would these fit with the 16V golf discs?
I’ve had a look at the faq entry and it doesn’t mention them, is there a way to get them to work?
Funky Diver
Re: Upgrading brakes - G60 Calipers
Post by Funky Diver »
Just get some 280mm discs. They're 280/22mm. If you're planning on sticking them straight onto your standard disc setup, there's gonna be roughly 20mm of the pad that's not gonna touch the disc. You'll get dangerous operation out of the brakes.
http://www.vwspares.co.uk/product_info. ... cts_id=507
RoccoYaz
Post by RoccoYaz »
You might need these as well:
http://www.justcaddys.com/280mm_brake_adapters.html
*Sorry i've read that you already have the carriers... :blush:
Darkside Performance Ltd
W: http://www.darksideperformanceltd.co.uk
E: darksideperformance@hotmail.co.uk
T: +44 (0)7717 746925
POWERED BY THE DARKSIDE
ash-lough
Post by ash-lough »
Will I be okay fitting 280mm under my 15’s?
What exactly is the list of things I will need:
G60 (Lucas 54) calipers
Carriers
Hoses
280mm Discs
Pads
Someone mentioned a slider kit??
RoccoYaz
Post by RoccoYaz »
ash-lough wrote:Will I be okay fitting 280mm under my 15’s?
Carriers
Hoses
280mm Discs
Pads
Not sure what a 'slider kit' is, but you should be fine fitting up to 280mm on 15" wheels. Corrado G60's have 280mm brake setup and 15" wheels as standard...
snathe
Post by snathe »
The G60 carriers wont bolt up to the Rocco (mk1 goof) front hubs dude... And i wouldn't recommend the adapter brackets as i've heard some horror stories about them :shock:
Get yourself a pair of mk2 golf 16v hubs, front coilies, bottom ball joins, steering arms & track rod ends and then the G60 set up will bolt straight on. (need to re-drill the rocco wishbone for the mk2 ball joint)
Can help you out with this conversion if you like dude
I'm currently fitting the above, but with Porsche 4 pots and a 280mm disc :yup:
'91 Pearl Green GT2 16v... Breaking
'80 MK1 GLS project... Sold
Chaps
Post by Chaps »
snathe wrote:And i wouldn't recommend the adapter brackets as i've heard some horror stories about them :shock:
Not heard any of these stories myself, more details please? I'm looking at making a few sets of adaptors thats all, and any info on this would be most helpful.
snathe wrote: I'm currently fitting the above, but with Porsche 4 pots and a 280mm disc :yup:
Pics please...... what porsche are the calipers off??? :hugegrin:
jimmyconway
Post by jimmyconway »
No. They won't fit under Ats Cups. 256mm will but your chances of finding the carriers are slim.
You will need Audi 80 carriers (74mm spacing) & Golf Mk2 calipers.
Good luck.
It's gonna be a good summer.
Funky Diver
But they do fit under other wheels...
