Looks like the Helios Scala's engine is still not right, see my previous post about problems with low oil pressure.
Basically, I ended up having the oil pump replaced which seemed to cure the oil pressure problem (blocked oil pump pickup and very worn pump).
Car has been fine since with no issues for about 2-3 weeks of use, but this morning when trying to start the oil pressure light stayed on at idle and oil pres gauge reads zero!! Arr.
So, anyone able to advise if its worth getting the bearings replaced if this is the issue, and a rebuild of the bottom end.
I assume that would be crank reground, main and con rod bearings replaced...
Or is it opening a can of worms, and should I be looking for an EX 1.8 engine the same to swap. Then I suppose I could keep my weber carb and other bits and pieces...
Any advice much appreciated, really hoped I'd got this sorted.
Chris
