I have been requested by my insurer to supply the engine number from my scirocco.
Where on the 1.8 block is the engine number located? Is the location different between 8v and 16v
engine number
engine number
insanecreations.net
insanecreations.net
- Funky Diver
Re: engine number
It should be on the engine block on the left side as you look at it (waterpump / alternator side) just under the cylinder head. Alternatively, if it's the original engine, and you have it present... it'll be on the chassis plate on the slam panel. Second line down IIRC.
Re: engine number
Cheers funky, I will move my alternator and have a look see
insanecreations.net
insanecreations.net
Re: engine number
On an 8v the engine number is on a small flat area at the top of the block just above and slightly to the left of the distributor.
No idea where it is on a 16v.
- Funky Diver
Re: engine number
You might not need to move the alternator mate, I've just checked on mine earlier and it's in full view, if you squint slightly and put your neck on a crick...Rusty dan wrote:Cheers funky, I will move my alternator and have a look see
