Starting friday morning (very early) the GT2 kept dying, every time i pressed the clutch down when coming to a stop
I thought this was just due to the cold as i had the same problem last year on cold mornings, so thought nothing more of it until i left work.
As friday was very warm in these parts, i thought it's not the cold, and after it died not 200 yards from work, i had to call the RAC who promply diagnosed the problem as a blocked jet in the carb, and turned up the idle speed so i could limp home
Once home, i (by that i mean mostly my dad
Anyhow, this was cleaned, refitted, and turned the idle back down, all seemed fine. also for good mesure at this point, i changed the fuel and air filters
Now whenever i'm driving, it will either idle around 1100 steadily, or bouncing around between about 500-700 - temprature or how long i've been driving dont seem to have any effect on where it idles. I assume the 1100 is becuase i didn't quite set the idle right, but i dont want to turn it down incase it causes it to stall when it idles lower
Engine is standard, however it is out of a ~90 jetta, carb is pierberg with a manual choke conversion
Thanks in advance for any help
Marcus
