Parking Light Won't Go Off
MikeH
My left side and tail light have decided to stay on - car is a '92 Scala i
My neighbour called to tell me my parking light was on this morning, so I nipped down, thinking I'd left the indicator in the parking light position, but it's not. The indicators still work normally, so I don't think it's the stalk.
Does anyone know a likely cause for this, or do I need to play 'hunt the short circuit'?
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
- scalainj
Re: Parking Light Won't Go Off
Do you have a factory fit alarm?
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
MikeH
No - there's an old GT Alarm in there, but it's mostly disconnected (never been armed in the 3 years since I've had the car)
- scalainj
Rules that out then.
I'd poke about the back of the fusebox as thet seems to be the primary cause of most ills - has it ever leaked in that area because the connectors corroade and casue all kinds of problems - i've replaced 2 or 3 now to remove electrical gremlins
Andy
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
- Risocco
Do factory fitted alarms cause this problem then Andy?
Alex
Alex
- Brunty
I've never even seen a factory fitted alarm!
Weird problem though Mike, let us know what you find.
Brunty
- Funky Diver
Sounds like a short to me, or a knackered relay... but I haven't delved into the nitty gritty of Rocco electrics in depth yet
- scalainj
Well i can't answer for all of them but occasionally mine does. Usually turning on/off/on/off/on/off sorts it but i have had to play with the connector to the alarm plus the fuses until it cures it. Age and corrosion plus dampness seems to be the issue. Sometimes it leaves al th eindicators on permantly which renders the indicators and hazards useless. Always a joyRisocco wrote:Do factory fitted alarms cause this problem then Andy?
Alex
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
- Risocco
Haha! I see bud, my project Golf has decided to do exactlly the same as Mikes car, and mine has a VW alarm you see. Resorted to taking the bulbs out of the indicators for a quick fix. Cheers for the info bud.scalainj wrote:Well i can't answer for all of them but occasionally mine does. Usually turning on/off/on/off/on/off sorts it but i have had to play with the connector to the alarm plus the fuses until it cures it. Age and corrosion plus dampness seems to be the issue. Sometimes it leaves al th eindicators on permantly which renders the indicators and hazards useless. Always a joyRisocco wrote:Do factory fitted alarms cause this problem then Andy?
Alex
Andy
Alex
MikeH
I think I know what the cause is ... a leaky boot lock seal.
- Funky Diver
