vented brake disc's
ashmini
vented brake disc's
Post by ashmini »
hey guys, my 86 rocco gt is goin in for some new brakes tomorrow, are the hubs the same as a golf gti so i can ask for vented disc's, excuse my stupidity if its an obvious peice of info
Re: vented brake disc's
assuming you've got sold discs on there at the moment, you'd need to change the caliper to move to vented discs. the discs is roughly twice as thick (25ish mm as opposed to 12mm) so there wouldn't be space within the caliper for the extra width of discs
filmidget
Post by filmidget »
You can fit vented discs to a solid disc equipped GT, you just need to fit the pads meant for vented discs at the same time
ie the calipers are the same, the pads are thinner to allow for the thicker disc.
(I did the same on my old GT)
LEEP
Post by LEEP »
filmidget wrote:You can fit vented discs to a solid disc equipped GT, you just need to fit the pads meant for vented discs at the same time
me two done that on my gt now :hugegrin:
SCIROCCO GT
Member 934
ashmini
Post by ashmini »
cheers guys, they put vented disc's on it, they said it already had em on, im like "iunno", i aint touchin them
