Mk1 Golf GTI Exhaust
mclean83
Post by mclean83 »
My mate is doing an ABF conversion on his MK1 golf GTI and has a surplus nearly new exhaust system inc manifold with 6 stud mount. I just wondered if anyone knows if this will fit my Scirocco so I can do away with my standard toilet bowl c clip exhaust manifold. my engine is the 1600 gt, the engine the exhaust came from is the 1.8I Gti.
Will
81GTi
Re: Mk1 Golf GTI Exhaust
Post by 81GTi »
manifold and downpipe will fit no problem but the rest will have all the exhaust hangers in the wrong places.
i fitted a mk1 golf exhaust to the scala when i first bought it. tail pipe needed extending 6" and a rear hanger added. easy to do if you've got access to a mig welder - just cut a straight bit off your old one and weld it on
