Which cylinder heads fit?
- walkinginperu
OK, so as above, which cyl heads fit onto an EW 1.6 carb'd engine block? I know some injection heads fit, but require some cheeky modifications of the old injector holes using coins/gearbox plugs, but has anyone got engine codes? This is to source a replacement head for my GT if mine hasn't been sorted after this weekend!
- Risocco
Re: Which cylinder heads fit?
Yeah, 1.8 carb and injection will bolt up mate, think new Beetle crossflow heads fit too. Perfect grounds for twin carbs?
Sent you PM mate in regards to heads.
Alex
Alex
MikeH
What age is yours? If it's post '86 with hydraulic tappets, then look for
Carb
EZ
GU
Injection (use pennies under the injector seats)
DX post 86
PB
EV post 86
Carb
EZ
GU
DX post 86
PB
EV post 86
1992 Scala ABF - SOLD
1989 Scala track toy. Dormant
1.6GL. 2 Owners, 60k. SOLD
- walkinginperu
Thanks Mike!MikeH wrote:What age is yours? If it's post '86 with hydraulic tappets, then look for
Carb
EZ
GU
DX post 86
PB
EV post 86
MikeH
No worries - there might be more (I'm not sure on the engine code for an 1800 carb Scirocco, for example). Those should be the common golf ones though.
- Brunty
I've got a 1.6 GT as my daily runner at the moment. It's got a really low compression engine, so I personally wouldn't bother fitting head/cams or carbs on to try and up the performance. IIRC it's got the same bore as the DX, so the head should just bolt on, but I think the con rods are shorter (or the crank has a smaller throw), which results in less compression and the 1.6 capacity.
Brunty
MikeH
^^ As Brunty says^^ it's a low compression engine. The head volumes are all about the same IIRC, but if you're tuning for performance you're better of starting with the 1800 or 2.0 block, or at the very least, heavily skimming the block or head (1.5 - 2mm in total, depending on your cam choice).
I read this thread as being about fixing a standard car, but if it's a tuning question, the answer changes a bit.
- walkinginperu
The question was more about fixing a standard engine than trying to squeeze any performance out. If my head is knackered then the injection/1.8 blocks seem to be a lot more common than the 1.6EW, that was the only reason for asking.
