Aup guys,
I've been talking a lot recently about running a supercharger on the new engine build. However, I'm not overly knowledgeable on after market engine management..Granted there a a kajillion websites with information about it on.
My question though, is 'what sort of pressures could safely be put through the K-Jet system and still have it work as well as it usually does?'...If any at all..
The way my brain is working is..If I run a charger on say..7/8psi which isn't too much compared to the 13/14psi you can run them at. Would the K-Jet still measure and adjust the fueling to handle the extra air..Or would I definately need to look into aftermarket management?
Forced Induction and K-Jet
Slumdogscala
Re: Forced Induction and K-Jet
In the 80's k-jet was standard equipment on a few forced induction cars including Audis, Porsches, Volvos and probably some others. There are definitely some metering head/air flow meter combinations that you could use with a supercharger but I'm not sure how well standard scirocco items would work.
89 scala inj.
86 ur quattro
83 chevette rally car (work in progress)
69 alfa 1750 gtv (work in progress)
86 ur quattro
- dozzum
foudn this when searching for stuff about k-jetronic.
http://www.tyresmoke.net/forum/vw-techn ... ction.html
turbod pinto engine running on it.
millsy20
Stealth Racing in Warickshire are good for this as they made multiple 1.8 16v turbos running on K-Jet. May be a good place to ring and pick their brains.
Rich
Rich
