Hi all
We have just got a 1988 sirocco scala auto, i have replaced the fuel pump and i have replaced the filler neck pipe with the bmw E36 one.
this mornning i got it to the mot station without it cutting out, great i thought it was the fuel pump then, he flew through the mot no probs. :D but on the way home he cut out three times it dont run rough or splutter before it cuts it just loses all power wont rev and dies :( i have to wait for ten mins before he will start again. could anyone tell me what the prob could be please. jen
cutting out
markh
Re: cutting out
Hi Jen, is it a carb model car ? How bad was the filler neck corrosion ? Its possible that theres still dirt, rust or water in the fuel tank from the filler neck problem. If you take out the lower part of the back seat and remove the circular inspection cover , you can whip out the fuel sender and have a look in the tank for any signs of contamination, also check out the fuel pick up for signs of blockage. If it is a carb car, then make sure the fuel filters clean, its also possible that theres dirt in the carb, it maybe worth whipping the jets out and giving them a blast of carb cleaner spray.
The ignition module (hall sender) can cause a similar problem too.
I have a similar problem with an 1984 1.6 carb GT im working on, but havent got round to sorting the running problem yet.
Hope this helps.
Hope this helps.
jen
Re: cutting out
Hi markh
The pipe just fell in half when i took it out, so quite bad, i will look in the tank tomorrow, oh and sorry yes its the carb model. still has the pierburg auto choke.
jen
jen
markh
Re: cutting out
If it was that bad Jen, then theres a good chance theres dirt/water in the fuel tank.
jen
Re: cutting out
Can you please tell me how you undo thething in the tank so i can get to the fuel sender,
1 hour and i still cant turn it. jen
jen
Re: cutting out
ops just broke the bloody thing and it still wont turn , phoned petter cooper they dont do them anymore, nor euro car parts. Any body got a spare one
ive now got fuel fumes pouring in to the car
jen
Re: cutting out
register here -
http://www.vagcat.com/epc/cat/vw/COR/1989/13/57/189469/
find part number if you dont already have it and then phone VW Dealer who MAY be able to trace one via the UK dealer network - thats what i did back in the summer to get one.
cant remember my log in on this machine so cant quote part number - your are looking for a fuel gauge sender for ex/carbed engined scirocco <1984.
they do crack easily.......................
jen
Re: cutting out
Hi gtxtra
i have found one £28.00 with post, now im fishing with a magnet in the tank, can see grainy bits but the magnet just wont pick them up, did try draining the tank with a pipe and sucking but got fed up with drinking the petrol. I dont wont to drain it from under the car as the hose was a bitch to get back on. jen
Re: cutting out
jen wrote:Hi gtxtra
avoiding halford yoof go to your local motor factors and get a syphon hand pump device - basically it's two pipes (one goes into filler neck or tank opening and the other goe into a jerry can) merging into one with a hand pump on one end - couple of quid , fiver tops.
Re: cutting out
if you end up wit rusty bits left in the tank, chuck the magnet in and leave it in there. the rust, plus any more you acquire from filling station tanks, will stick to it
jen
Re: cutting out
Thanks Nate
i have just emptyed the tank ,with a turkey baster
that has melted wiped the tank with rag tied to a rod and have fished with a magnet, i will put in in there when i put the sender back in as i broke it getting it to unscrew, have one that should arive today. how easy is it to clean the jets in the carb, im trying to do all i can to stop this cutting out. thanks for the tip jen
Re: cutting out
unscrew them and blow thru them with carb cleaner. don't poke anything down them as they wear easily and are very precisely made
