Hi, Does Anyone have any guides or tips on how to remove the front and back bumpers off a mk2 ?
As the paint is all flaked and need resprayed.
How To Remove Bumpers ??
Tim_R
Re: How To Remove Bumpers ??
Open the bonnet and undo the 4 19mm bolts that hold it to the chassis legs then pull. Disconnect the foglamps if you still have them first. For the rear, open the boot and undo the 4 bolts and again it should slide off. :D
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
mind your toes- when bolts off the bumper will slide out quite quickly.
also the ambient temperature sensor is plugged into the back of the osf section of bumper.
But only if you're fuel injected.GTXTRA wrote:also the ambient temperature sensor is plugged into the back of the osf section of bumper.
It's an easy job (unlike getting the plastic covers off the bumper irons, which is a pain in the arse).
- jimmyconway
Say what? Is that for real?GTXTRA wrote:also the ambient temperature sensor is plugged into the back of the osf section of bumper.
It's gonna be a good summer.
jimmyconway wrote:Say what? Is that for real?GTXTRA wrote:also the ambient temperature sensor is plugged into the back of the osf section of bumper.
as ed pointed its just on the injected cars( which came with a trip computer combined with the clock - amongst other things it shows ambient temp).
- bluestreak56
