Evening all...I have gearbox oil leaking from around the driveshafts. Does anyone have part numbers or links to where I can find the gaskets?
1.8i DX engine, manual gearbox if that helps!
Thanks in advance
Gearbox Oil Leak
hanna.melbo
- GT_II
Re: Gearbox Oil Leak
Repair kit is 020498085E, only available as an aftermarket part, plenty listed online. I think that is what you are looking for. I based this on a 1990 model year, but I guess that it would suit all DX engined cars
https://www.classic-vw.co.uk/020-gearbo ... 5130-p.asp
https://www.classic-vw.co.uk/020-gearbo ... 5134-p.asp
https://www.classic-vw.co.uk/020-gearbo ... 5136-p.asp
you will need a compression type clamp to be able to push the driveshaft cup flange in a bit to release the circlip holding the cup flange on
only then can you change the seal
