Guys,
Looking at a few sets of vintage wheels for my MK2, I've seen a set of old Alpha's from an Alfasud. They are 4x98.
I've read that wobble bolts allow you to put 100's on a 98, but does that work both ways, allowing you to put 98's on a 100?
I don't mind a bit of work if there's a method.
Wheels Query - 4x98
Fresco3000
Fresco3000
Re: Wheels Query - 4x98
The Bore on the VW is 57, the bore for the Alphas 58. So if possible with wobble bolts I'd also need spigot rings?
1980 Mk1 Scirocco GLi / 1986 T25 Caravelle / 1989 Mk2 Scirocco GT
Fresco3000
Think this can work with a set of 58.6mm - 57.1mm spigot rings.
Like these:https://ej-parts.co.uk/spigot-rings-hub ... mm-57.1mm/
And a good set of wobble bolts. Obv there's some care to be taken on fitting.
