Wheels Query - 4x98
Fresco3000
Wheels Query - 4x98
Post by Fresco3000 »
Guys,
Looking at a few sets of vintage wheels for my MK2, I've seen a set of old Alpha's from an Alfasud. They are 4x98.
I've read that wobble bolts allow you to put 100's on a 98, but does that work both ways, allowing you to put 98's on a 100?
I don't mind a bit of work if there's a method.
1980 Mk1 Scirocco GLi / 1986 T25 Caravelle / 1989 Mk2 Scirocco GT
Fresco3000
Re: Wheels Query - 4x98
The Bore on the VW is 57, the bore for the Alphas 58. So if possible with wobble bolts I'd also need spigot rings?
Fresco3000
Think this can work with a set of 58.6mm - 57.1mm spigot rings.
Like these:https://ej-parts.co.uk/spigot-rings-hub ... mm-57.1mm/
And a good set of wobble bolts. Obv there's some care to be taken on fitting.
