Scirocco Storm Mk1 1980 Wiper Arm
paulc1967
Post by paulc1967 »
I need a new wiper arm for the front screen. Anyone got one or have any ideas on a substitute fix. it is of course the single sweep arm. My existing arm has shredded its splines to a smooth surface over the past 40 years.
GT_II
Re: Scirocco Storm Mk1 1980 Wiper Arm
Post by GT_II »
I think the splines are self-cut in the arm by the shaft. If the splines on the shaft are clean and sharp, there are a few fixes suggested online, including inserting an aluminium strip from a drinks can, which might just tighten it up enough for the splines to get a grip.
paulc1967
Post by paulc1967 »
GT_II wrote: Thu Jun 17, 2021 10:04 am I think the splines are self-cut in the arm by the shaft. If the splines on the shaft are clean and sharp, there are a few fixes suggested online, including inserting an aluminium strip from a drinks can, which might just tighten it up enough for the splines to get a grip.
Thanks for the suggestion. May be worth a try if conventional sources fail to find a replacement part or an alternative fix using other VW assemblies.
