Oil Temp, Voltage etc cluster
JOH
Post by JOH »
Can anyone tell me what the three gauge cluster is generally referred to as ie oil temp, battery voltage etc which is found above where the radio sits? My '89 Scala injection basically has a void where I guessing this should be and keen to source a working item and struggling to find a replacement.
Thanks!
eefy
Re: Oil Temp, Voltage etc cluster
Post by eefy »
Hey fella, Tom over at Dreadnought Customs produces these-
https://dreadnoughtcustoms.co.uk/collec ... ack-finish
Post by mr.brown »
Mk2 Sciroccos only ever came with single gauge next to the ashtray - and even then that was limited to the GTX - which had a VDO Voltmeter.
All the other models had a square blanking plate - but underneath you'll still find the 52mm hole. Dreadnought also do a plate replaces that the hard-to-find factory original and allows you to retrofit that single gauge
https://dreadnoughtcustoms.co.uk/collec ... ngle-black
A common modification is to cut out the ash tray and the gauge "holder" thereby creating a "DIN" sized opening - basically a car stereo sized hole. You can then fit a triple gauge holder like the one linked to by Eeefy.
As for which three gauges - the usual is Volts, Oil Temp and Oil Pressure. The reason for this is that many 1980s Audis came with all three fitted and can still be found for a reasonable price. Be aware that you'll need a specific oil pressure sender - but that's another story....
GT_II
Post by GT_II »
The instruction manual shows two alternative single gauges - oil temperature or voltage. I'm guessing oil temperature would be a more useful function if no MFA.
JOH
Post by JOH »
Cheers guys. So its a ashtray and volt meter I need to find. Spot on.
Thanks for the advice!
JOH
Post by JOH »
Storm console with ashtray and oil gauge purchased via flea bay. £35. Sorted.
Cheers guys!
Simonpiemon
Post by Simonpiemon »
I've just fitted these to mine.. Bought the triple gauge holders from dreadnought customs and wired them up with senders provided
essextom
Post by essextom »
Simonpiemon wrote: Sun Mar 29, 2020 7:59 pm I've just fitted these to mine.. Bought the triple gauge holders from dreadnought customs and wired them up with senders provided
6 gauges! someones greedy :-)
Simonpiemon
Haha yes I'll send you a picture when I've got the last two in 👍
essextom
Post by essextom »
Simonpiemon wrote: Mon Mar 30, 2020 1:33 pm Haha yes I'll send you a picture when I've got the last two in 👍
yes mate
What's going in the last 2 spaces?
Flux capacitor charge and destination time/year ?
:-D
JOH
Post by JOH »
Sorry forgot to ask - any thoughts on which oil pressure sender or where to get one? cheers
chopperoli
Post by chopperoli »
mr.brown wrote: Wed Mar 25, 2020 1:57 pm Mk2 Sciroccos only ever came with single gauge next to the ashtray - and even then that was limited to the GTX - which had a VDO Voltmeter.
There were also Mk2 GTI's which had a single vdo oil temperature gauge (150°c)
I always think
voltmeter: just confirms what you already knew- flat battery
oil pressure: it will just make you worry more!
oil temperature: only really needed on the autobahn :D
Post by mr.brown »
It makes sense that earlier models had it too - as the centre console always had the facility for a gauge. However, I had an 82 1.6GTi and 84 1.8GTI and neither had a gauge.
Simonpiemon
JOH wrote: Thu Apr 02, 2020 10:55 pm Sorry forgot to ask - any thoughts on which oil pressure sender or where to get one? cheers
I got one on ebay are you using mechanical or digital gauge?
