Glove box key for 1989 scala
Philcraig
Post by Philcraig »
Hi
Does anyone have a lock and key for a 1989 scala?
If not does anyone know if it is possible to get a blank ‘VW’ key and then get it cut to my existing lock?
Many thanks
Phil
Blueshark
Re: Glove box key for 1989 scala
Post by Blueshark »
Get yourself a new lock with two keys and adjust the rest to it except for the fuel lid, you can not take that apart.
191 905 855 lock cylinder for ignition starter switch
F >> 53-H-027 544 until 1987
1
1H0 905 855 A lock cylinder for ignition starter switch
F 53-H-027 545>> from 1987 1
Joost
Philcraig
Post by Philcraig »
Great thanks!
Philcraig
Post by Philcraig »
Hi
I’ve bought a set of 2 keys and a new barrel but it seems as though the pinch lock is a sealed unit.
Does anyone know a way of removing the lock barrel from the glove box?
Thanks in advance
Blueshark
Post by Blueshark »
The lock barrel is held in place by two plastic tabs on either side of the barrel,
warm them up a bit (to avoid breaking) and carefully bend them aside a bit and the barrel will come out.
Joost
