Could some kind Sir or Madam please tell me where the bolts are hidden to remove the heater control section.
Our bulbs are all bust minus one and i finally have some to fit :)
Mick
Dash heater control lights mk2
scirocco_ne
- Blueshark
Re: Dash heater control lights mk2
scirocco_ne wrote: Thu Dec 20, 2018 12:17 am Could some kind Sir or Madam please tell me where the bolts are hidden to remove the heater control section.
Mick
No bolts or screws. just remove the controll buttonsand the swictch knob and pull out the panel on either side with your fingers
Joost
There is 2 types of heater control panel, early type has a bulb which you can remove by pulling it out of its holder and the later type the bulb is built into the control panel, you can change it but you need to carefully split the panel open to gain access the the bulb..
scirocco_ne
Mine was replaceable but i didnt have any so butchered the unit to take a dolls house bulb soldered in :D... Now her dolls house conservatory is abit more mood lit lolmark1gls wrote: Thu Dec 20, 2018 10:05 pm There is 2 types of heater control panel, early type has a bulb which you can remove by pulling it out of its holder and the later type the bulb is built into the control panel, you can change it but you need to carefully split the panel open to gain access the the bulb..
