Fuel filter required
				hanna.melbo
Struggling to find a fuel filter for a mk2 1.8i storm.... Looks like a small inline metal cylinder that sits on top of air filter housing. Any suggestions as to where I can get this from? Or part number? I have tried all the mainstream parts places but all seem to provide the wrong one!
									Re: Fuel filter required
I'm 99% certain it's the first one - but you can get them much cheaper at Euro Car Parts.
Their website is incorrect though, for the Scirocco they always come up with a plastic inline filter. But if you plug in details for a Golf Mk1 1.8 GTI, you get the right one.
https://www.eurocarparts.com/ecp/c/Volk ... 244&000140
https://www.eurocarparts.com/ecp/c/Volk ... 3f2&000140
1987 GTX (Flash Silver)
				hanna.melbo
Spot on fellas, thanks! Goes to show its getting harder to get even the basic parts for these cars now!
eBay also sells them.
Also look under Mk1 golf as they use the same smaller fuel filter on early cars.
Nearly all the mechanical parts are available some where and if you are having trouble find stuff there is a thread on here about suppliers or just ask and I’m sure we can help.
				moser
https://www.vwspares.co.uk/product_info ... ts_id=1362
This is the one i ordered but didnt get round to fitting yet.
03 Seat Cordoba PD130 - Daily
That’s the later bigger fuel filter, yes it will fit your 1990 Scirocco, pre 85 ish used the smaller fuel filter.moser wrote: Mon Jul 16, 2018 9:56 am https://www.vwspares.co.uk/product_info ... ts_id=1362
The VW part number is 433-133-511 for the Storm. Volkswagen still carries these, or you can get a filter from Bosch as Bosch number F 5021 / 71020. You are probably aware of it, but just in case, there are also some copper sealing rings for the fuel lines which should also be replaced when you change the filter.
									Mk2 Scirocco Storm
Mk3 Golf GTI VR6
						Mk3 Golf GTI VR6
				hanna.melbo
Thanks for the help, all done! thats another job ticked off the list, now on to the next 200!
