Lots of oil in the metering head
BlackGTX
Post by BlackGTX »
Hello,
Fired up the 16v gtx today and let it run for half hour, noticed oil coming out the bottom of the airbox and lots in the metering head
What would cause this volume to enter the airway
Valve seals is the prefered worst case
blakey
Re: Lots of oil in the metering head
Post by blakey »
It could also be piston rings or even head gasket.
A dry and then a wet compression test would confirm valve seals or rings. I would imagine that there is excess pressure when taking the oil filler cap of whilst it is running.
Sent from my ZTE BLADE A512 using Tapatalk
'89 Sapphire Scala Inj.
Member No. 1455
BlackGTX
Post by BlackGTX »
Was thinking about it today and it may be the routing of the block breather so ill clean it up and discpnnect it and go again and see what happens
Then ill probable just get a hg kit and get a good look at the cylinder walls
