Drive Shaft Oil Seal!?
Atom
Post by Atom »
Hi all!
I’ve noticed a splatter of oil around the drive shaft as it meets the gear box.
I’m going to start with the drive shaft oil seal but can’t find a part anywhere.
I assume and hope it is a shared part and may just need to order a golf one with the same gear box! If so which one is it?
I have a 1990 1.8 5spd
Re: Drive Shaft Oil Seal!?
best person is to ask mark carter on this web page
https://www.classic-vw.co.uk/transmission-939-c.asp
Atom
Post by Atom »
james butler wrote:best person is to ask mark carter on this web page
Thanks James i’ll drop Mark a message.
Many thanks
Adam
no probs matey
worst comes to worst ive bought one from euro car parts before now and it fit fine.
im yet to find out what the difference is between them all, if you do contact mark could you ask him for me :chortle:
do you know how to change them?
its a bit of an involved job a so you have to remove the driveshafts off the gearbox and damage other parts to get to the seal so dont forget to order these too
https://www.classic-vw.co.uk/020-gearbo ... 5134-p.asp
to get them out you prise them out with a screw driver which ruins them
to put new ones in bang them in with a socket and hammer
Atom
Post by Atom »
Cheers James,
That’s good to know, thank you. I did try Euro Car Parts but could t find anything. I’ve just put an order in at ECP full service and a new Rad, ready for the new season.
I’m very fortunate to have a good friend who is a mechanic and loves a good classic motor to work on for tea and biscuits :)
Seals for drive shaft flanges.
https://www.ebay.co.uk/itm/VW-GOLF-MK1- ... XQ01tRSzhO
Not a difficult job to change them, really easy with gearbox off the car but harder with gearbox on car as things get in the way and lying on you back on the floor is never easy but do able.
Ive done it twice with the gearbox on the car and once with the gearbox on the bench.
You do need to make a tool to hold the flange in place while removing the Circlip as it’s under pressure from a big spring behind the flange.
You will need some new gearbox oil and good time to change to fully synthetic to help with cold oil.
Oil I’ve been using in both cars for a few years, 2 bottles is plenty.
https://www.eurocarparts.com/ecp/p/car- ... &0&cc5_868
Great website and everything you ever wanted to know about the gearbox.
http://www.brokevw.com
one of these you will be needing
https://www.google.co.uk/search?q=o2o+g ... eVkoLM5EUM:
although im sure your mechanic should be well aware
Atom
Post by Atom »
Thanks again for the recommendation and help getting the right parts. Mark at Classic VW .co.uk is a sound chap and wouldn’t hesitate recommending the site and service.
Jack92
Site Admin
Post by Jack92 »
Atom wrote:Thanks again for the recommendation and help getting the right parts. Mark at Classic VW .co.uk is a sound chap and wouldn’t hesitate recommending the site and service.
Can’t agree more!
I actually went up to see him today to pick up a new gearbox and the amount of stuff he has in the unit would make for a treat for anyway :-)
Jack
South East
www.motorsportdiscounts.co.uk
Ford Transit 2.0 - Work Horse
Jack
South East
VW Scirocco Scala MK2 1.8 Inj
Jaguar F-Type
