Can you manually do up an electric window?
WINDOW!
- Blueshark
Re: WINDOW!
No you can not, you have to undo the window from the mechanism and push it up by hand and block if you want to shut the window
Re: WINDOW!
Don't just pull the glass up or you may pull it out of the clamp which holds it at the bottom.
