WINDOW!
Delahaye92
WINDOW!
Post by Delahaye92 »
Can you manually do up an electric window?
Blueshark
Re: WINDOW!
Post by Blueshark »
No you can not, you have to undo the window from the mechanism and push it up by hand and block if you want to shut the window :-)
Re: WINDOW!
Don't just pull the glass up or you may pull it out of the clamp which holds it at the bottom.
