Don't know German? look here
DannyH
Posts: 604 Joined: Wed Apr 01, 2009 11:21 am
Post
by DannyH » Fri May 12, 2017 2:07 pm
Hi Guys in desperate need of a front strut, the outer bit, as above
does anyone know the part number and where i can get one?
ta much in advance
ps is it the same as a MK1 Golf?
Danny
unknownmale
Posts: 991 Joined: Tue Jul 23, 2013 2:34 pm
Post
by unknownmale » Sun May 14, 2017 4:31 pm
I went through this a few months ago, after buying inserts, had to clean up and reuse my original ones.
Aren't the Bilstein ones a single piece?
Posts: 3957 Joined: Thu Apr 02, 2009 9:28 pm
Post
by mark1gls » Sun May 14, 2017 4:32 pm
I know what you mean about the part number, etka only lists the strut and shock.
They do pop up 2nd hand every now and then when someone changes over coil overs.
Blueshark
Posts: 1228 Joined: Tue Apr 07, 2009 9:28 pm
Post
by Blueshark » Sun May 14, 2017 8:33 pm
The housing has never been sold separatly.
Only complete with shock, when shock is gone you buy an insert.
Joost
DannyH
Post
by DannyH » Mon May 15, 2017 12:37 pm
Ta Guys
they are complete with inserts.
the really annoying bit is i had a spare pair of housing and some swine nicked them out of our yard a few years back.
Danny
DT1
Posts: 709 Joined: Tue Dec 08, 2009 10:07 pm
Post
by DT1 » Mon May 15, 2017 5:49 pm
Do you still need a single strut? I have 3 so one is spare.
Edit: Ho hum...just saw your other thread.
DannyH
Post
by DannyH » Mon May 15, 2017 6:38 pm
Thanks anyway
Danny
