Frount Strut outer
NEW section - if you're having a mare with Vagcat and need a quick answer stick your requests in here. Keep things simple and only reply if you know the correct answer.
Don't know German? look here
DannyH
Frount Strut outer
Post by DannyH »
Hi Guys in desperate need of a front strut, the outer bit, as above
does anyone know the part number and where i can get one?
ta much in advance
ps is it the same as a MK1 Golf?
Danny
Re: Frount Strut outer
Mk1 golf and Mk1 cabriolet use the same strut so might give you some more options?
http://www.golfmk1.co.uk/Items.php?cat= ... SUSPENSION
Or here?
http://www.classic-vw.co.uk/front-suspension-1013-c.asp
Not sure if you need a shock as well and don't replace just 1 shock. Not sure if these struts you can remove unscrew the nut and remove the shock? Might be worth an email to find out?
Part number here?
https://volkswagen.7zap.com/en/rdw/scir ... 11-102000/
DannyH
Post by DannyH »
Thanks Mark
still can't find a number for just the housing, i gave up and bought these
http://www.ebay.co.uk/itm/252164717607? ... EBIDX%3AIT
Danny
unknownmale
Post by unknownmale »
I went through this a few months ago, after buying inserts, had to clean up and reuse my original ones.
Aren't the Bilstein ones a single piece?
- David
I know what you mean about the part number, etka only lists the strut and shock. :-(
They do pop up 2nd hand every now and then when someone changes over coil overs.
Blueshark
Post by Blueshark »
The housing has never been sold separatly.
Only complete with shock, when shock is gone you buy an insert.
Joost
DannyH
Post by DannyH »
Ta Guys
they are complete with inserts.
the really annoying bit is i had a spare pair of housing and some swine nicked them out of our yard a few years back.
Danny
DT1
Post by DT1 »
Do you still need a single strut? I have 3 so one is spare.
Edit: Ho hum...just saw your other thread.
DannyH
Post by DannyH »
Thanks anyway
Danny
