My door seals are cracked and leaking - it's not helping that my car is kind of tilted to one side due to the state on the road after the council resurfaced it!
I've found out that the part number I need is 867 867 365 G but no longer available anywhere. has anyone undertaken this - if so is there another similar door seal which would work?
thanks!
door seals mk2 scirocco
- Blueshark
Re: door seals mk2 scirocco
Vintage rubber in the USA have them, not cheap but better than water in the car ..
http://www.vintagerubber.com/SciroccoMk2DoorSeal.aspx
Joost
Joost
Car Builder Solutions do lots of rubber seals, have a look in their catalogue. Whilst they don't do one the same cross section as the originals, there may be a moulding which would provide an effective seal. If you speak to them they will probably send you some short lengths to see if one appears to do the trick. Cost is around £5 per metre.
OK thank you! I looked on the car builder site seems to be a fair few options there if it would stop raining I could have a good look at it!
if not I'll have to pay £100 for a door seal - ouch!!!! this is becoming an expensive hobby I'm putting it through an MOT on Monday dreading it!
thanks again!
thanks again!
Gemma
On my 1st Scirocco - '91 Black GT2 (which is driving me crazy!)
- Blueshark
My door seals are ready for shipping through Thomas or Essex Tom on here.
Mede to the specs of the original ones.
Let me know if you are still in need of these.
Joost
Joost
Hi, do you still sell door seals? Noticed i have a steady drip coming from the bottom of the glass
- Blueshark
I still have the reproduction door seals in stock.
https://scirocco-delen-eimers.nl/portie ... cirocco-2/
Regards Joost
