Hi all,
I'm getting a rear plate made up for show use, it will just say Scirocco on a standard front plate format but pressed into an aluminium plate.
My question is if anyone knows any German and the use of the special letters, I'm thinking I get
Sciröccö
But am unsure...
Any help would be great!
Rear plate - German...
T33stat
Blueshark
Re: Rear plate - German...
Scirocco doesn't have an umlaut (ö) in German on either 'o.' The function of the umlaut is to change the pronunciation of the vowel - in this case to something like "shiroehkoeh" - probably making you sound like you come from Barnsley.
But you can do it if you want. It's your car.
scrumpyone
lol Edthe edmundator wrote: in this case to something like "shiroehkoeh" - probably making you sound like you come from Barnsley.
Dave
Register No:1110
'79 MK1 GLS (R.I.P.)
'91 MK2 GT2 (alive & kicking)
Register No:1110
T33stat
Don't want anyone thinking I'm from Barnsley!
Going to go for plain letters :)
Lukeh17
As I am German speaker I wouldn't use the Umlaut unless we are changing the pronunciation of Scirocco ;). As you are probably aware, they say it the same apart from 'r' which is pronounced from the back of the throat ;)
