Rubber Boot on lower steering CV joint
Hey everyone,
I need to change the rubber boot on the lower steering CV joint. However the part here:
https://www.vwheritage.com/shop/scirocc ... iants-rhd/
looks smaller than the part currently on.
Looked at the diagram on vagcat and the part looks bigger than what VW heritage is showing
http://www.vagcat.com/epc/cat/vw/COR/1988/13/52/183204/
Number 5 on there
Number 5 on there
- scrappy1382
Re: Rubber Boot on lower steering CV joint
cant see the 2nd one as not registered , but the 1st one from vw heritage will be fine fella. oh just a friendly tip. the spring is a bugger if you try to take short cuts with this
Scirocco Shane
84 Havanna Brown Storm -
Cool. Yeah the position of it too looks a nightmare to be honest. Thanks for the tip mate!! :)
- scrappy1382
no worries, if you need a hand, gimme a shout
Scirocco Shane
to get the boot off i undid the steering rack mounts and slid it forward, then undid the bolt securing the lower column to the rack (make sure you mark up the position before disconnecting).
because you are changing the old one for a new one i would just cut the old one off first so you can see what you are doing as its a bit of a bugger to get to.
once the lower column is disconnected from the rack you can install the new boot.
then refit opposite to removal.
i dont remember a spring though scrappy1382? you have got me worried now as i must have either left mine off or it got lost!
- scrappy1382
whilst stripping the dash apart on mine ( chasing wires that melted together ) i did however notice the 'spring' was infact on the steering coloumn where the peddles arejames butler wrote: i dont remember a spring though scrappy1382? you have got me worried now as i must have either left mine off or it got lost!
cant get it right all the time unless double checking things over lol
Scirocco Shane
ah i got you, so the springs on the other side of the knuckle joint on the steering coloumn side?
- scrappy1382
yes bud.
Scirocco Shane
So just to clarify (as I have said in previous messages, I am new to this sort of stuff and fortunately I haven't been faced with many challenges etc but need to learn more about the mechanical side).... I need to cut the old one off then undo the bolt that connects the lower steering column to the rack (marking up the position before I disconnect it) Why is this?. Once undone I can slide the new boot up the column before re bolting up the lower steering column to the rack again.
http://www.partsbase.org/vw/scirocco-sc ... track-rod/
is it no.19 that I need to unbolt?
Thanks for the help guys
yes mate you got it.
the reason you disconnect the knuckle joint to the rack is so you can slide the boot into place then reconnect it back up afterwards.
to be fair its a fairly straightforward job just a bit fiddly.
Sweet thanks for your help
- scrappy1382
luke, as mentioned before, if you really are unsure on doing this, then i offer my services for coffee and bacon butty'sLukeh17 wrote:Sweet thanks for your help
Scirocco Shane
Sweet cheers mate
I found this a royal pain ( lots of upside down inside out and muttered profanities ) then I realised that it is quite easy to loosen the steering rack itself and the whole job becomes far more pleasant, it's the millimetres that count :)
