Clanging spring noise at full steering lock
- Macc
Only noticed this yesterday, was quite alarming to be honest but have been told that its probably nothing to worry about. Question is, is it?
1990 MK2 1.8 GTII Scirocco "Black Shuck"
Little_bro
Re: Clanging spring noise at full steering lock
Probably strut top mounts. There cheap and easy to change
- Macc
Cheers fella, ill have a gander at that first then!
Do you mean the noise happens as you turn the wheel, or it happens while driving on full lock?
If it is the first one, check you don't have a broken front spring. This isn't common on original springs (but not unheard of) but aftermarket springs may well have been fitted. This wants checking asap, as if it comes out of its seat while driving it isn't fun
- Macc
Righto, methinks Dave the mechanics going to have to have a look at that on Wednesday then, apparently they are new springs but I'll let him pass judgement!
- unknownmale
Is it only when turning in one direction? If it's more of a click and it's relative to your speed I would suggest CV joints.
- Macc
Both directions, and it definitely sounds like a spring
Is it when turning the steering wheel it does it, or when you actually drive?
- Macc
only when moving on full or near to full lock Nate
my brother had a very similar sounding problem and it turned out to be a knackered front spring.
turn the steering lock to lock and no noise untill you pulled forward then clang!
- Macc
Had Dave the mechanic on the phone today, on mine its the front strut top mount of the suspension, bearings are seized up. Brand new on order! Little_bro was spot on!
fair play, should be nice easy fix then. make sure your mechanic doesn't split the suspension leg from the hub or he will have to set the camber all up again and its a pain to get right.
- Macc
Just come back from a test drive with Dave the mechanic, new top mount on (the other bizarrely wouldnt fit so he transplanted the bearings), both were seized solid. Quite the difference now!! So much easier to turn!
Quite sad to leave it again, only the carb upgrade and exhaust repositioning to go and its all done
could you ask your mechanic how he did this?Macc wrote:new top mount on (the other bizarrely wouldnt fit so he transplanted the bearings), both were seized solid.
i didnt think top mounts could be disassembled?
if they can, please let me know and how.
- Macc
Ill ask him mate no probs (when I go to pick the car up, whenever its finally finished!)
