I know the oxygen free cable will be for speakers and assume brown is earth and red live but unsure on the blue/white wire and the red wires with bullet connectors on
Any help much appreciated
Matt
There should be rear speakers in the parcel shelf supports of a mk2. Even if they're gone you may find the wires tucked up somewhere behind the dash.MattRocco wrote: Yeah I think it's just the two front door speakers. Not entirely sure as I thought it's supposed to have rears in the shelf type bits? Never looked though.
YesMattRocco wrote: I got a Sony headunit to go in so if I don't need the illumination wire should I just tape the end off and leave it be?
Into the ISO connectors? If you have a standard aftermarket ISO harness all the colours will be the same.MattRocco wrote:I don't suppose you know the in which Pin numbers the wires go in the connectors? Or have a old picture kicking around
