Hi guys, at some point one of the previous owners of my Rocco has not just removed the radio but physically cut out and the connectors so all I'm left with is a bunch of wires. I've got a few ISO connectors kicking around but need to know what wire to what pin so I don't plug it in and set something on fire!
I know the oxygen free cable will be for speakers and assume brown is earth and red live but unsure on the blue/white wire and the red wires with bullet connectors on
The brown is indeed earth, the main red cable will be permanent live (run a multi-meter across it) and the red spur from that live will be for a radio that required a switched live. The blue and white cable looks more blue and grey, if that is the case it is the illumination (not required on modern radios).
So I presume that there are only two speakers? If you are going to run four speakers you will have to fit two more speaker cables.
If you get a radio that requires a switched live then I suggest taking the feed from the blower switch (yellow and black cable) including an inline fuse, solder in and cover with heat shrink.
As I said before, use a multi-meter to check and disconnect the battery before messing with the permanent live.
My eye sight is not so good it seems! :)
Yeah I think it's just the two front door speakers. Not entirely sure as I thought it's supposed to have rears in the shelf type bits? Never looked though.
I got a Sony headunit to go in so if I don't need the illumination wire should I just tape the end off and leave it be?
Cheers for the advice guys! I don't suppose you know the in which Pin numbers the wires go in the connectors? Or have a old picture kicking around
There should be rear speakers in the parcel shelf supports of a mk2. Even if they're gone you may find the wires tucked up somewhere behind the dash.
Yes
MattRocco wrote:I don't suppose you know the in which Pin numbers the wires go in the connectors? Or have a old picture kicking around
Into the ISO connectors? If you have a standard aftermarket ISO harness all the colours will be the same.
Hey guys I got amoungst sorting some interior bits out I notcied there is also a grey wire with no other colours on, where does this need to go to on the ISO? Sorry for all the questions
