Hi All
As above over the weekend the temperature gauge is flashing. It normally does this on startup if I remember correctly four or five times and then goes out. However it is continuing to flash. Any ideas?
Pete
Flashing red light on temp gauge
Re: Flashing red light on temp gauge
The light will continually flash if your coolant is low on an injection car, check that first!
Ive had a look and it would appear the coolant was a bit low so will top that up later and see whats what
Thanks Ian
Thanks Ian
Hopefully it was just low coolant. If it comes back, you can find some more information in this thread:daveyg wrote:Ive had a look and it would appear the coolant was a bit low so will top that up later and see whats what
Thanks Ian
viewtopic.php?f=11&t=14239&p=113230&hil ... sh#p113230
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
Mk3 Golf GTI VR6
Thanks Thomas
I topped the coolant up and that has resolved the issue but thanks for the link
Pete
Pete
