Gearbox gone
Gearbox gone
Just went to the Chinese after backshift and went to go into 2nd and it was reluctant and there was a large bang and now 2nd doesn't really work and sounds like something has broken off and is rattling around in the gearbox.
The most expensive Chinese I've ever had.
Start off slow and methodical, that doesn't work so shout curse and hit it till it works.
1255
1255
Re: Gearbox gone
That doesn't sound good
Re: Gearbox gone
Anyone got a spare gearbox or want to make me an offer on the car as is?
1255
1255
Re: Gearbox gone
Gearboxes turn up mate, they are pretty numerous in the usual places.
I hope the experience hasn't put you off being a Scirocco owner!
bensspares
Re: Gearbox gone
my brother has a 5 speed sports box from a gtx. Its covered 120 k with no issues or crunches. Located in Otley Yorkshire. Let me know and will speak to him if you want it. £75.
Re: Gearbox gone
Cheers bensspares I'll think about it but Im in two minds as its going to be too much to do for me I think.
1255
1255
Tim_R
Re: Gearbox gone
Where are you based? Maybe someone nearby can offer some help and advice if you need it.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
Re: Gearbox gone
Mate, don't let it put you off. I had to have a gearbox change done on an ex-girlfriends scirocco back in the '90's, I felt really bad as it was me that told her to get a Scirocco instead of a Corsa!
A decent garage can change one in about one and half hours and you may as well do the clutch also for good measure!
Re: Gearbox gone
Don't kill a perfectly good car for the sake of a gearbox, please.
1985 GTL 1.8
Re: Gearbox gone
I'm in Workington, West Cumbria. Any help would be great
1255
1255
Re: Gearbox gone
You should be able to find somewhere that will recondition your gearbox for around a couple-of-hundred quid.
Re: Gearbox gone
Got a feeling this is my problem but garage will confirm it tomorrow. http://www.scirocco.org/faq/drive/ thing is though I haven't noticed any gear oil.
1255
1255
Re: Gearbox gone
Right a poser for you good chaps. My shagged gearbox is a AUG code and I have found a reconditioned one but it is an AMC code. From what I can gleam from das net is that; AMC is a 020 gearbox, AUG is 020 type too and they both are 8v. AMC are from early mk3 golfs and have 24mm Input Shafts whilst AUG have 22mm Input Shafts.
Is this right? If so can I fit an AMC to my car or am I shafted by a big(ger) shaft?
1255
1255
Re: Gearbox gone
WHEY! The White Stallion rides again! £300 and a month later my Scala is back on the road
1255
1255
