this week i've had a delivery of these, fresh back from my local sand blasting place
a lick of paint, a delivery from the local motor factor and some skinned knuckles, and i've got me a built up rear axle
for those of you struggling to fit the rear ARB clips, here's how i did it -
little bit of KY jelly on the rubber so the metal can move on it, then pinch it up with a mole grip. i replaced the bolt thing you adjust the grip with a normal bolt. once i'd got it clamped as tight as i could i got a spanner on the bolt to pull it all the way in so i could slide on the clip. top marks to haynes on this one with one of their least helpful descriptions ever.
drums and all internal gubbins are new, using meyle parts
