rear wiper
pasenah
rear wiper
Post by pasenah »
Hi, the Spline in the rear wiper is worn down an no longer moves the wiper arm.
Is there a fix or is it a new motor?
Re: rear wiper
standard roadside repair for these is to wrap the spindle in a bit of foil (old style kitkat wrapper good for this, or cigarette packet liner) and replace the arm. not a permenant repair by any means, but will keep it going a while longer.
is it definately the spindle and not the arm that has worn?
pasenah
Re: rear wiper
Post by pasenah »
Yeah it the spindle as I've taken the arm off and its pretty much worn smooth. If I tighten it as much as I can it doesn't help As it stops it moving at all. Without the wiper the spindle turns freely when switched on.
I'll try your tips but its so warn I'm doubtful I'll work. I might try some plumbing thread tape.
Can the spindle be replaced or is it a complete motor?
Re: rear wiper
It's a pretty easy replacement fella, the whole unit unbolts.
May have a spare
pasenah
Re: rear wiper
Post by pasenah »
Cool, send me a quote if you like but postage may be a bit high to Cornwall?
pasenah
Re: rear wiper
Post by pasenah »
Any luck with that spare Mr funk?
Re: rear wiper
Re: rear wiper
I most certainly do have it and it works.
Need to check with the buyer of the Bootlid that he doesn't need it though
pasenah
Re: rear wiper
Post by pasenah »
Ok thanks, just let me know.
pasenah
Re: rear wiper
Post by pasenah »
Also, if you still have the rear 3point seat belts, how much for the lot?
pasenah
Re: rear wiper
Post by pasenah »
Did you get my message re. having the seatbelts, Jim?
Re: rear wiper
Yes matey. Mikei is taking the whole unit I'm afraid but the seat belts are yours.
pasenah
Re: rear wiper
Post by pasenah »
No worries. Thanks
