I need to get some pipes for my oil cooler, I am running an early style oil cooler where the pipes connect to the top of the Oil filter housing.
Can somebody let me know the size of the fitting into the holes?
Russ
golf mk1/scirocco oil cooler pipe fitting size
insanecreations.net
insanecreations.net
Re: golf mk1/scirocco oil cooler pipe fitting size
Are you looking for the threaded union that screws into the hole on the filter housing or the hose connector that screws onto the threaded union?
PeteGLi wrote:Are you looking for the threaded union that screws into the hole on the filter housing or the hose connector that screws onto the threaded union?
both sizes would be good as i am making my own :D
insanecreations.net
insanecreations.net
Thread pitch both ends is metric 1.5
The end that screws into the housing looks like 15 mm and the end that the hose screws onto looks like 17mm.
Why don't you buy new ones - Part Number 049 117 233 Adapter.
all sorted, 16mm parallel thread with washer
thanks
thanks
insanecreations.net
insanecreations.net
