is the tank presurised
thebrief_1979
Is the tank on an 92 mk2 gt2 (carb) pressurised - the petrol cap does not seem to have a rubber seal but I was 'informed' that I shoul hear a pressurised hiss when I fill up ?
1993 MK2 Flash Red GT2 - sold
Mk1 gls - nearly
Mk1 gls - nearly
Re: is the tank presurised
The tanks are ventilated, so I think they shouldn't become pressurised, although it does happen. I wouldn't worry if yours doesn't hiss, it probably just means air is replacing fuel as intended.
- filmidget
Tanks aren't pressurized... As above, more likely a slight vacuum may build up and hiss.
However pretty sure the cap should have a seal, and I think recent-ish changes mean the car should fail an MOT test if the seal is missing.
Nate should know...
Nate should know...
I've never seen an MOT man take the fuel cap off?
I would think that it should have a seal on the cap, both of my Mk1's do, carb and injection.
yes, it should have a rubber seal on it. Loads of testers don't bother checking though. If you are getting a vacuum building up in the tank, it would suggest you have got a seal on the capmark1gls wrote:I've never seen an MOT man take the fuel cap off?
